Старый 03.09.2018, 21:12   #1
d365technext: Default Dimension D365FO AX-2012
Источник: http://d365technext.blogspot.com/201...o-ax-2012.html
Following Code will help you to create Default Dimension using X++
Default Dimension Class
public class DefaultDimesnionHelper
public static DimensionDefault createDefaultDimension(container conAttribute,container attributeValue)
DimensionAttributeValueSetStorage valueSetStorage = new DimensionAttributeValueSetStorage();
DimensionDefault result;
int i;
DimensionAttribute dimensionAttribute;
DimensionAttributeValue dimensionAttributeValue;
// Note that "Item" is not one of the default dimension,
// but DimensionAttributeValueSetStorage will handle it gracefully
container conAttr = conAttribute;
container conValue = attributeValue;
str dimValue;
<div class="MsoNormal"> for (i = 1<span style="font-family: "consolas"; font-size: 9.5pt;">; i
d365technext: Create Customer using X++ D365FO & AX-2012 Blog bot DAX Blogs 0 03.09.2018 15:11
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 10:52
Часовой пояс GMT +3, время: 13:55.
