Если запустить этот скрипт без конфига вообще получаем такую ошибку:
X++: Microsoft CRM Error Report: Error Description: CS1513: } expected Error Details: c:\Program Files\Microsoft Dynamics CRM\CRMWeb\Files\notes.aspx(19): error CS1513: } expected Full Stack: [HttpCompileException: c:\Program Files\Microsoft Dynamics CRM\CRMWeb\Files\notes.aspx(19): error CS1513: } expected] at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert) at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert) at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath) at System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFactory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath) at System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig) at System.Web.HttpApplication.MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) Other Message: Error Number: Source File: c:\Program Files\Microsoft Dynamics CRM\CRMWeb\Files\notes.aspx Line Number: 19 Date: 11-19-2010 Time: 01:00:58 Server: crmsrv02 Request URL: http://crmsrv02:5555/Files/notes.aspx?guid={07A71E60-2EF3-DF11-BB70-003048BE732D} веб конфиг отсутствует. в чем ошибка подскажите пожалуйста. Было бы очень хорошо отладить этот скрипт чтобы не придумывать решение проблемы с нуля. |
А если в папку Files
скопировать конфиг CRM-а 4.0 То получаем такую ошибку X++: Server Error in '/' Application. -------------------------------------------------------------------------------- Configuration Error Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately. Parser Error Message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. Source Error: Line 50: </assemblies> Line 51: </compilation> Line 52: <authentication mode="Windows" /> Line 53: <identity impersonate="true" /> Line 54: Source File: C:\Program Files\Microsoft Dynamics CRM\CRMWeb\files\web.config Line: 52 Show Additional Configuration Errors: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (C:\Program Files\Microsoft Dynamics CRM\CRMWeb\files\web.config line 57) -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:2.0.50727.3615; ASP.NET Version:2.0.50727.3614 |
Теги |
crm, аннотации, вложения, выгрузка файлов, приаттаченные файлы, прикрепление файла, примечания |
