А если в папку Files
скопировать конфиг CRM-а 4.0 То получаем такую ошибку X++: Server Error in '/' Application. -------------------------------------------------------------------------------- Configuration Error Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately. Parser Error Message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. Source Error: Line 50: </assemblies> Line 51: </compilation> Line 52: <authentication mode="Windows" /> Line 53: <identity impersonate="true" /> Line 54: Source File: C:\Program Files\Microsoft Dynamics CRM\CRMWeb\files\web.config Line: 52 Show Additional Configuration Errors: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (C:\Program Files\Microsoft Dynamics CRM\CRMWeb\files\web.config line 57) -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:2.0.50727.3615; ASP.NET Version:2.0.50727.3614 |
Теги |
crm, аннотации, вложения, выгрузка файлов, приаттаченные файлы, прикрепление файла, примечания |
