#4 |
Проблема в том. что этот код периодически затирает весь инфолог, а не только те строки, что записались при DuplicateKeyException . Воспроизвести не всегда получается. Если я отлаживаю код в дебаггере, то все ок. Если без дебаггера запускаю, то периодически исчезают строки из инфолога.
Я грешу на метод X++: Counter logCount = infologLine(); Цитата:
This method has similar functionality to the <c>xInfo.line</c> method, but it improves performance
/// and lowers network load when you are executing server-side code.When the <c>xInfo.line</c> method /// is run on the server, it makes a call to the client to retrieve the number of lines in the Infolog /// buffer. The <c>xGlobal::infologLine</c> method retrieves the server-side Infolog buffer line count. /// This eliminates the requirement to call to the client. When the <c>xGlobal::infologLine</c> method /// is called on the client, it returns the count directly from the Infolog buffer on the client.This /// method is especially useful when you write server-side code that processes exceptions.The number of /// lines in the Infolog is generally stored before entering a <c>try</c> / <c>catch</c> block.If an /// exception occurs, the number of lines that were previously stored is used to determine which /// messages were logged during the code in the <c>try</c> block. If no exceptions occur, the stored /// Infolog buffer line count is often unused. If you use the <c>xGlobal::infologLine</c> method /// instead of the <c>xInfo.line</c> method to retrieve the Infolog lines, a round-trip to the client /// is prevented. /// </remarks> X++: xInfo.line Последний раз редактировалось IKA; 02.12.2014 в 20:25. |
