Старый 21.04.2016, 14:49   #30
мдя... на большой базе пришлось подбирать фильтры. в принципе там получалось минут 20 на всю выборку в 15млн результирующих записей.
вот какие запросы были:
-- наивный: 4% по плану запроса, выполнено за 1:24, выбрано 342294 записи
with trans as (
SELECT
    isnull(accTable.SUMACCOUNT, isnull(accGroup.SumAccount, accAll.SumAccount)) as pSumAccount,
    tr.*
from custtrans as tr
join custtable as tab on (tab.accountnum = tr.accountnum)
left join CUSTLEDGERACCOUNTS as accTable
    on (accTable.DATAAREAID = 'eras'
    and accTable.POSTINGPROFILE = tr.POSTINGPROFILE
    and accTable.AccountCode = 0 and accTable.NUM = tab.ACCOUNTNUM)
left join CUSTLEDGERACCOUNTS as accGroup
    on (accGroup.DATAAREAID = 'eras'
    and accGroup.POSTINGPROFILE = tr.POSTINGPROFILE
    and accGroup.AccountCode = 1 and accGroup.NUM = tab.CUSTGROUP)
left join CUSTLEDGERACCOUNTS as accAll
    on (accAll.DATAAREAID = 'eras'
    and accAll.POSTINGPROFILE = tr.POSTINGPROFILE
    and accAll.AccountCode = 2)
where tr.DATAAREAID = '3r'
  and tab.dataAreaId = 'edat'
select *
from trans
where trans.pSumAccount in ('62.02.01', '62.02.02', '62.02.02', '62.01.09')
-- row_number, 87% по плану запроса, выполнился 4:39, выбрано 342294 записи
with trans as (
SELECT --top 100
    la.SUMACCOUNT as pSumAccount
    ,row_number() over (partition by tr.DataAreaId, tr.RecId, la.dataareaid, la.POSTINGPROFILE order by la.ACCOUNTCODE) as acc_rn
    ,tr.*
left join CUSTLEDGERACCOUNTS as la
    on ( la.dataareaid = 'eras'
     and la.POSTINGPROFILE = tr.POSTINGPROFILE
     and la.num = (case la.AccountCode
							when 0 then tab.AccountNum
							when 1 then tab.CustGroup
							else la.num
							end)
select *
from trans
where trans.acc_rn = 1
  and trans.pSumAccount in ('62.02.01', '62.02.02', '62.02.02', '62.01.09')
-- подзапрос: 8% по плану запроса, выполнился за 1:59, выбрано 342294 записи
with trans as (
select
	(select top 1 SumAccount
		from CustLedgerAccounts as la
		where la.PostingProfile = tr.postingProfile
							else la.num
							end)
			and la.dataAreaId = 'eras'
		order by AccountCode  ---- <----
		) as pSumAccount
	,tr.*
inner join custtable as tab on (tab.AccountNum = tr.AccountNum)
select *
from trans
прикольно.
А есть у кого-нибудь объяснение таким результатам?
И как можно сделать оптимальнее?
Последний раз редактировалось mazzy; 21.04.2016 в 16:19.
Произвольный SQL-запрос listener DAX: База знаний и проекты 26 26.07.2016 09:31
Пользовательские настройки. Выборки формы r2d2 DAX: Функционал 1 13.11.2014 11:37
Автоматический выбор профиля разноски при создании заказа ada DAX: Функционал 15 30.06.2005 14:46
Настройка профиля разноски модуля Основные средства mnu DAX: Функционал 24 23.06.2004 09:45
Собственный SQL запрос в FormDataSource Alexey DAX: База знаний и проекты 0 20.12.2001 00:35
Часовой пояс GMT +3, время: 21:33.
