Старый 19.12.2012, 11:11   #1
25,644 / 848 (80) +++++++
emeadaxsupport: When creating a view receiving an error indicating not authorized to access table.
Источник: http://blogs.msdn.com/b/axsupport/ar...ess-table.aspx
Example of issue:
1. Create a view that joins 2 related tables. I used CustTable as root table, and custTrans as related table.
2. Do not add any fields to the view.
3. Right click on the view and select open.
Actual:
You receive an error message that says
"You are not authorized to access table 'custTable’ (custTable). Contact your system administrator."
The message is misleading as the actual issue is no fields have been added to the view from the CustTable or CustTrans tables. To address the error message add field/s to the view.
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
emeadaxsupport: The Report Server Configuration ID could not be found in the SRSServers table Blog bot DAX Blogs 0 09.10.2012 17:11
emeadaxsupport: Opening a Report on AX 2012 raises infolog error: The default Report Server Configuration ID could not be found in the SRSServers table. Blog bot DAX Blogs 0 02.12.2011 00:13
emeadaxsupport: Error when deploying ODC files: Development site is not found in the EPParameters table Blog bot DAX Blogs 0 09.01.2010 05:05
Часовой пояс GMT +3, время: 06:57.
