#7 |
Сообщение от oleg_e
![]() ......падает на следующей ошибке:
Deploying 0 data source(s) and 6 design(s) in 43 culture(s) (258 item(s) total)... Unable to connect to http://oleg:88/ReportServer/ReportService2005.asmx as specified in the config file for the report server at C:\Program Files\Microsoft SQL Server\MSRS10.MSSQLSERVER\Reporting Services\ReportServer\RSReportServer.config. If this url is not correct please update the config file, otherwise make sure the report server is configured correctly. The deployment log file can be found at "C:\Users\oleg\AppData\Local\Temp\tmpF157.txt"
This posting is provided "AS IS" with no warranties, and confers no rights. |
За это сообщение автора поблагодарили: sao (1). |
Теги |
ax2009, reporting services |
